RCT Axpert VM2 firmware download?
As a point of interest, what version does it come with?
This seems to be a very recent model.
Edit: It seems to be equivalent to the MPPSolar PIP-GEW series (3024 and 5048).
  • 1 year later...
On 2024/11/14 at 5:24 AM, Bassemubid said:
43.05
I note that there is an older firmware version 43.05 whose hex file is dated 2022-10-11, and is different. The one above may be for the "premium" (refresh?) VM II model.
Both 43.05 firmwares are only for 1200 W 12 V or 2500 W 24 V models.
The older 43.05 supports both the QGMN command (returning 029, for VM II non-export), and QMN command (returning VMIII-2500 or VMIII-1200). The newer one above only has the QMN command, also returning VMIII-nnnn. It looks like they are trying  to unify the VM2, VM3, and VM4 firmwares, at least to a degree.
@Bassemubid, thanks for sharing  the firmware update.
43.02 → 43.05
The older 43.02 supports both the QGMN command (returning 029, for VM II non-export), and QMN command (returning VMIII-2500 or VMIII-1200). The newer one above only has the QMN command, also returning VMIII-nnnn. It looks like they are trying  to unify the VM2, VM3, and VM4 firmwares, at least to a degree.
I want dsp for 2.5&3k premium 43.20
  • 1 year later...
