August 3, 20233 yr Hi, I've had my solar install for a few weeks now and I have been trying to get to grips with Home Assistant. I have been trying slipx06's Dash and ESPHome code. I have an ESP32 board hooked up to the inverter. I have managed to get so far. I have the powerflow working and I have started to play with the control settings. I am struggling to set the times for the grid charge. I can turn the grid charge options on / off and change the SOC % and charge power but I cant change the times. Is it because all the settings that I can change are pulled in as a controls but the clock settings are pulled in as a sensor? When I click on the time to try and change it I just get the history popup. Any ideas would be appreciated
August 3, 20233 yr Hi @JonWarby You will need to update the ESPHome config and setup additional sensors as input numbers. I don't change my time settings so never configured them. Something like this number: - platform: modbus_controller # 250 System Mode Time 1 use_write_multiple: true modbus_controller_id: sunsynk name: "${friendly_name} System Mode Time 1 Start" id: sunsynk_esphome_system_mode_time1_input address: 250 value_type: U_WORD Edited August 3, 20233 yr by slipx
August 3, 20233 yr Author Ah, ok, thank you, so I had it working as designed? I thought I had messed something up. I am on an agile electricity tariff that varies from day to day so sometimes on the days where there isn't a huge amount of solar I may need a nightly top up of the batteries and the cheapest slots will vary. Thank you. Will look to give that a go tomorrow.
August 4, 20233 yr Author I had a go with this on just the first timer. I moved the #250 section under the number section of the config file and changed the elements you suggested above. After pushing the code it changes the element to a number value. It seems to drop the : so for example 00:30 is read as 30. 2:30 is read as 230. If I change the values on the sunsynk app I can see those changes come through to Home Assistant. The number is also editable now so I can type in a new number in the time slot. Whatever number I enter seems to be ignored and after a few minutes just gets refreshed with the value that it's defined in the app. I think this is the part of the log that is relevant [11:46:27][D][number:113]: New number value: 200.000000 [11:46:27][D][modbus.number:061]: Updating register: connected Sensor=SunSynk System Mode Time1 start address=0xFA register count=1 new value=200.00 (val=200.00) [11:46:27][D][number:012]: 'SunSynk System Mode Time1': Sending state 200.000000 [11:46:28][D][modbus_controller:032]: Modbus command to device=1 register=0xFA countdown=0 no response received - removed from send queue I assume that it's not happy with the value and not accepting it Edited August 4, 20233 yr by JonWarby
