Mecer SOL-I-AX-8M2 Optimal settings,firmware, BMS settings for Hubble AM5
Good day.
I have just installed my Mecer SOL-I-AX-8M2 inverter with two Hubble AM5 batteries.
The inverter is unable to communicate to the Hubble master Battery via CAN port and BMS port on the inverter.
Anyone got this working?
Is there any updated firmware for this inverter?
Some appliances restart for example my TV & TV Box when the grid fails when the inverter switches to the batteries other appliances like the fridge stay on. Is there optimal settings that I am missing the prevent this?
Thank you in advance.
Firmware images attached
You probably need updated display firmware, if you need any at all. Sadly, 32.xx is not in my collection as yet.
There is slightly updated main firmware at the below link, and you can even try the lightly patched firmware as well to see if it improves solar production.
