Solar panel advice
We have 10x 550watt Canadian solar panels. I would like to add 6 more. Are there better on the market or should I add the same? Can I mix and match or should I stick to the same?
Thank you.
Thank you.
Rather stick to what you have as they are still available.
More info like inverter make and model to say if you can expand to 16 panels.
Thank you.
How are the existing 10 connected 1 string 2 strings 1 mppt 2 MPPTs what is the inverter make and model why do you need to add more panels? Never a good idea to mix and match unless you already have panels you want to utilize.
