August 13, 20233 yr What Gas Geyser would you guys recommend? Waterflow at my house is around 15l per minute. I am quite keen on Ariston or Dewhot's forced fan units because Rinnai is currently sold out everywhere. What would you guys recommend or what do you use at your house? I am also quite interested in knowing what VSD booster pumps would be recommended? I have a 0.37kw peripheral unit, but would like to get a Leo Mac550, Scala Grandfos 1 or a Zilmet Magicbox Maxi. Just for the shower and to have the convenience of not losing pressure when 2 taps are open as the 0.37kw can't keep up.
August 13, 20233 yr 4 hours ago, KoosRoos said: What Gas Geyser would you guys recommend? Waterflow at my house is around 15l per minute. I am quite keen on Ariston or Dewhot's forced fan units because Rinnai is currently sold out everywhere. What would you guys recommend or what do you use at your house? I am also quite interested in knowing what VSD booster pumps would be recommended? I have a 0.37kw peripheral unit, but would like to get a Leo Mac550, Scala Grandfos 1 or a Zilmet Magicbox Maxi. Just for the shower and to have the convenience of not losing pressure when 2 taps are open as the 0.37kw can't keep up. Not sure if Dewhot is the best but for sure they are good enough for many people. Interesting that the 0.37kW does not work well for you. Mine supplies a better pressure than the munic can supply at over 15L/min. Further I have found 5L/min to be good enough in my caravan shower. Are you using about a 25mm supply pipe from the pump to the dwelling or a great distance? Remember 1 x elbow has the same loss as 10m straight pipe.
September 7, 20232 yr Hi everyone, any recommendation of a best 20L gas geyser? This electricity is getting out of hand 🙈
