August 14, 20233 yr Hello,  does anyone have firmware for MCU ideal 15.09 or 15.11 available? Or newer?  I am solving a problem with communication with BMS 😞   Â
August 15, 20233 yr Author Aaaaa  I found out that the newer revision of the axpert king rack already has a board with GD32 (ie 16-501444-00G)  so the firmware should be 115.9+ ... then I loaded 112.22 into the MCU and checked if it somehow works....
March 17, 20242 yr Hello Michk I have the same inverser with an error code 9 after trying make communication beetween théis inverter ans a pylontech US2000C battery Do you have any information or manual about this electronic card ?!?  Â
March 20, 20242 yr On 2024/03/18 at 4:07 AM, Briztou said: I have the same inverter with an error code 9 Unfortunately fault code 09 is usually a sign of a serious hardware problem, like many blown MOSFETs. Was there a loud bang? Burning epoxy smell? I hope I'm misunderstanding.
