Axpert King 5KW Rack(RM) firmware for MCU
Hello,
does anyone have firmware for MCU ideal 15.09 or 15.11 available? Or newer?
I am solving a problem with communication with BMS 😞
Aaaaa
 I found out that the newer revision of the axpert king rack already has a board with GD32 (ie 16-501444-00G)
so the firmware should be 115.9+ ... then I loaded 112.22 into the MCU and checked if it somehow works....
  • 7 months later...
Hello Michk
I have the same inverser with an error code 9 after trying make communication beetween théis inverter ans a pylontech US2000C battery
Do you have any information or manual about this electronic card ?!?
On 2024/03/18 at 4:07 AM, Briztou said:
I have the same inverter with an error code 9
Unfortunately fault code 09 is usually a sign of a serious hardware problem, like many blown MOSFETs.
Was there a loud bang? Burning epoxy smell?
I hope I'm misunderstanding.
