September 1, 20232 yr Good day I have a new growatt spf5000es inverter. Ingle li battery and 6 x 465w panels (longi) . My problem showed up today showing no amps from the panels. Voltage shows 135v with a 2 x 3 panel configuration. Any help will be appreciated Regards Frik58
September 1, 20232 yr 28 minutes ago, Frik58 said: Good day I have a new growatt spf5000es inverter. Ingle li battery and 6 x 465w panels (longi) . My problem showed up today showing no amps from the panels. Voltage shows 135v with a 2 x 3 panel configuration. Any help will be appreciated Regards Frik58 Check the MPPT PV input Voltage spec on the inverter. Operating Voltage 120V - 450V or thereabouts. Your 3Series x2Parallel configuration should likely rather be all 6 in series. On less sunny days especially you are skirting on the edge of being outside the range.
September 1, 20232 yr MPPT start up voltage is 150 + or - 10V. You need to restring your panels into one series string.
