September 3, 20232 yr Good day all. Installed above inverter. 2 questions. 1. What is correct South African server for shine app? 2. Time keeps kicking back to 15.00 even if i set it to 09.00 I assume because i set the shine info to US SERVER it auto sets time to there. I can not get app to connect to datalogger. Blue light flickers but it just wont connect. My assumption is because the server info might be incorrect, the time difference is causing havoc. I hope this is correct and with the correct server detail the problem will be solved. Thank you in advance. Edited September 3, 20232 yr by wareddel
September 3, 20232 yr 2 hours ago, wareddel said: Good day all. Installed above inverter. 2 questions. 1. What is correct South African server for shine app? 2. Time keeps kicking back to 15.00 even if i set it to 09.00 I assume because i set the shine info to US SERVER it auto sets time to there. I can not get app to connect to datalogger. Blue light flickers but it just wont connect. My assumption is because the server info might be incorrect, the time difference is causing havoc. I hope this is correct and with the correct server detail the problem will be solved. Thank you in advance. Just ensure you set your own time zone to our zone but be careful of some similar zones like Cairo that intrudused day light saving.
March 15, 20242 yr @wareddel I'm curious about this inverter and considering buying it to replace my Luxpower SNA5000 as it keeps blowing fuses on my 2 AV receivers and garage motor on odd occasions. I think I counted over 20 fuses in my garage window cemetery today. Is this SPF6000 good? Besides the time zone thing are there any concerns since you started using it? Does it blend power if you don't have enough PV in the morning and blend battery in the evening? Please let me know. Thanks
