September 12, 20233 yr Any advise or assistance will be appreciated. Kodak 7.2 connected via RS232 to S port of Hubble Cloudlink. Cloudlink connected to 2 x Hubble AM2's via CAN. Because of this connection, I am not utilising the Hubble BMS. If I connect the S port from the Cloudlink to the Hubble, I activate the BMS. Is there a converter / switch / cable that can convert the Kodak RS485 or RS232 port to communicate with the Cloudlink CAN or Modbus port? This will allow continued remote functionality to the Kodak but with BMS activated. Thank you.
