Wanted: Kodak/Axpert LCD unit
Item Wanted: Kodak / Axpert King LCD/Control unit
Mine has given up, suspect something blew. It wont even turn the inverter on, right now I've bypassed it using the RJ45 pin 7 & 8 method. Inverter is working fine.
Any replacement from a broken inverter or spare is fine, I can flash the correct firmware.
Packaging Essential: No
Desired Age: Any
Willing to accept a shipped item: Yes
Ballpark/Budget Amount: R500?
Replacement LCD screen for Conversol Axpert King Solar Inverter, bluetooth
Edited by Not From Eskom
Indeed, suspect an eskom surge fried it. The main AC fuse in the inverter also popped, which has since been replaced and the inverter is working albeit without the LCD/display unit. I took the removable display into an electronics repair shop and they said it cannot be repaired.
42 minutes ago, CyberJoe said:
I presume that by now you have come right, but if you have not, I bought one from Shumata, was sub R500 for the board.
https://shumata.com/
Great, I see they also stock fans for just about the entire Kodak range, and because Kodak is rebranded Axpert, these fans are also good for other rebranded machines, eg. Mecer, RCT etc.
Theres frequently members trying to source axpert fans, so good to know.
Edited by BritishRacingGreen
