October 2, 20232 yr Hello I've got 2 Growatt SPF 5000 ES, i want to connect them to a parallel mode, single phase output. The question is, can i feed in each of the units with different phase from the grid, or they should be feed in with the same phase of the grid? One phase will not be enough to me. if not possible to use 2 different phases, is it possible to configure the 2 units to work with 2 phase system also for the output (instead of 3)? Thanks Arthur
October 2, 20232 yr You won't be able to sync them from 2 phases,you can run them as 2 seperate inverters on 2 phases but this isn't making sense,how won't a single phase be enough? Or is the issue you need to back up 2 phases?
October 2, 20232 yr Author the feed in phases are 23A 230V each. the loads is about 10KW, so in order to provide it i need to use 2 23A phases of 3.
October 2, 20232 yr Author if i will run them as 2 separate inverters, should i connect any communications cable between them as they are going to be connected to the same battery?
October 3, 20232 yr Author You won't be able to sync them from 2 phases,you can run them as 2 seperate inverters on 2 phases but this isn't making sense,how won't a single phase be enough? Or is the issue you need to back up 2 phases? the feed in phases are 23A 230V each. the loads is about 10KW, so in order to provide it i need to use 2 23A phases of 3. if i will run them as 2 separate inverters, should i connect any communications cable between them as they are going to be connected to the same battery?
October 3, 20232 yr Author Running Split Phase mode (not connecting the Current Sharing cable) thanks for your answer. just to be sure, i feed in each inverter with different phase (240V each phase) of the grid and on the output of both inverters i will get a single phase of 240V that i can combine in to a one switch? PS my Growatt 5000 es is Europe version, not US
October 3, 20232 yr thanks for your answer. just to be sure, i feed in each inverter with different phase (240V each phase) of the grid and on the output of both inverters i will get a single phase of 240V that i can combine in to a one switch? PS my Growatt 5000 es is Europe version, not US No,you can't switch and combine phases like that Why do you have such low amperage phases? This makes zero sense
October 3, 20232 yr Author No,you can't switch and combine phases like that Why do you have such low amperage phases? This makes zero sense because the solar system is connected to a sub panel that connected with thin cables that i can't replace. so i guess that i need to configure the two units as a 3 phase system but without the third phase inverter
October 3, 20232 yr Are you confusing multiple inputs and multiple phases possibly? Or is the Main DB 3 phase and has 3 phases into your Sub DB?
October 3, 20232 yr Author Are you confusing multiple inputs and multiple phases possibly? Or is the Main DB 3 phase and has 3 phases into your Sub DB? Main DB 3 phase and has 3 phases into Sub DB The main has 40A each phase and Sun has 25A each phase
October 4, 20232 yr Ah alright,you'll need to install a 3-phase to single-phase transformer before the load then to combine phases
October 4, 20232 yr Author Ah alright,you'll need to install a 3-phase to single-phase transformer before the load then to combine phases Thanks, i probably will buy another Inverter and make it 3 phase system for the house
October 4, 20232 yr Thanks, i probably will buy another Inverter and make it 3 phase system for the house This won't combine the phases though
October 4, 20232 yr Author This won't combine the phases though it's ok that they will not be combined, i will use each phase separately
