Recommended Pylontech Current
Hi All,
I wanted to query what is the recommended charge current for 4x 3.5kw 48v US3000C? I recently added in Solar Assistant for monitoring and the page recommends a charge current of 37.0A, but I'm unsure if this is per battery or for the entire battery bank.
There is an issue with the amps being displayed by Solar Assistant on the battery pack. I did highlight it to Solar Assistant but still not changed.
Check under each battery what the current is or go to battery setting and see what the BMS is requesting from inverter.
image.thumb.png.bf682ec843ed91b8b4b22792c52d6b11.pngimage.png.bdf79ca373b3ff9c232355c76c832a8e.png
Thanks for the reply Jacques. This is the current call setting. I hope this is what you are referring to.
I set the charge from solar to max 120A, which is the fuse limitation i have of 125A
Also noticed the cycles per battery, is that used or cycles left?
image.png.1a2887ab336c619eef6680bbede7d129.png image.thumb.png.1bbdb834613a6100a4a2edd4b3fba2d1.png image.thumb.png.348cec2f70273fe010c0ecfd21747040.png image.png.a1828b229a2ede47b0c86181bfe7d460.png
