For Sale: Solis S6 Pro 6 kW Hybrid Inverter [Sold]
Item: Solis S6 Pro 6 kW Hybrid Inverter
Age: 5.5 months - used for 4 months
Price: R 16000
Payment Method Accepted: EFT
Warranty: Balance of 5 year manufacturer warranty
Packaging: Complete, in box
Condition: As per new, in box, all components provided, fully functional
Reason: Used for testing/evaluation purposes, upgraded to 8 kW version
Shipping: Not available
Collection: Available
Link: https://powerforum-store.co.za/products/solis-s6-pro-6kw-advanced-hybrid-inverter
WhatsAppImage2023-11-17at11_36.39_2fa04b91.thumb.jpg.8e8fa3f807a5e372f6c5b3c40cc5fbdf.jpg
WhatsAppImage2023-11-17at11_36.39_dbf91880.thumb.jpg.e9d23cf60b118c747e3921ad0fadddfc.jpg
WhatsAppImage2023-11-17at11_36.40_0c8c8f6b.thumb.jpg.1ef2b1041aace1d461ea829f3787b6f8.jpg
Edited by AlexTZA
  • AlexTZA changed the title to For Sale: Solis S6 Pro 6 kW Hybrid Inverter
If I'm not mistaken this is the only 6kW fanless inverter on the local market.
And it has a lovely indictor for the battery level
Very sleek and clean asethetic when I saw it in person
Good afternoon, @AlexTZA
I am looking to replace my Sacolar 5kw with either a Sunsynk, Deye or potentially the Solis you have listed above.
I currently have a Deichmann 4.8kwh battery.
Does the solis have compatability to add used defined settings for the battery, or a general setting for lithium batteries, as my battery is not listed in the Solis’s manual.
thanks in Advance
Werner
Hi @Hager
I must admit I've never heard of the Deichmann battery until now 😄
However, I see it uses the rather ubiquitous Pace battery BMS which effectively uses the Pylontech CAN BMS protocol. I've tested a Greenrich battery with the same Pace BMS with the inverter and it worked perfectly fine using the Pylontech settings - no need to do any manual battery configuration. You could confirm this by speaking to the battery distributor (TheSunPays) - I'm fairly certain they will confirm the battery will work with any inverter that can talk the Pylontech CAN BMS protocol. Just bear in the mind the battery will only support a max of 4.8kw discharge power.
Edited by AlexTZA
  • AlexTZA changed the title to For Sale: Solis S6 Pro 6 kW Hybrid Inverter [Sold]
