Chris Olivier Posted November 18, 2023 Share Posted November 18, 2023 It is a new plant all updates & versions were updated to both inverters check coms cable changed also coms cable but slave inverter still give error F29 parallel canbus fault reset & restart inverters but still the same only master inverter working Normal & slave with error F29 also no usage are ahown on the solarman app the inverter & dongle coms are there as they do show all online on the app any other ideas solving this We also changed the master & slave inverters and set it up again but still same ishu Quote Link to comment Share on other sites More sharing options...
