November 23, 20232 yr Hello Friends I found a very interesting addition to HA. Can be installed as an add-on for Home Assistant OS and supervised, Docker in standalone mode or Legacy method using a Python virtual environment Links: https://emhass.readthedocs.io/en/latest/intro.html https://github.com/davidusb-geek/emhass https://community.home-assistant.io/t/emhass-an-energy-management-for-home-assistant/338126 Quote: EMHASS (Energy Management for Home Assistant) is an optimization tool designed for residential households. The package uses a Linear Programming approach to optimize energy usage while considering factors such as electricity prices, power generation from solar panels, and energy storage from batteries. EMHASS provides a high degree of configurability, making it easy to integrate with Home Assistant and other smart home systems. Whether you have solar panels, energy storage, or just a controllable load, EMHASS can provide an optimized daily schedule for your devices, allowing you to save money and minimize your environmental impact. EMHASS is not easy to run, but it can be very useful in energy management. I invite you to discuss Edited November 23, 20232 yr by slaw
November 27, 20232 yr This is where energy management needs to go, I hope the project matures to become viable
