Growatt spf5000es switch from Utility to battery
Good day
I have a growatt spf5000es, I was just wondering if someone maybe knows if it is possible to switch the AC output source of the inverter at a certain time to go from Utility to battery?
Thanks in advance.
This you can do in your settings OR if you want to run on your battery at certain times, just cut (switch off) the input trip switch that feeds the ac to the inverter.
