DIY 3KW 5.12kwh trolley - operational since March 2023
Not going to go into too many details, and a lot was already shared in other threads, but thought I would create this thread, should someone want to get some inspiration or ideas when it comes to building your own "Inverter Trolley".
History
During the December 2023 holidays, my dad and I were discussing options to combat loadshedding, having a little 555W portable unit (which worked remarkable well to keep the TV and DSTV on) as well as a 1440W Ellies trolley with 2 X 105Ah LA batteries (standard pre-assembled). Obviously these two were not enough, so we started toying with the idea of building our own trolleys ... and thus the project started
Design
Building off of the trolley concept, with a couple of changes:
1. 3KW inverter needed - to keep at least the fridge going, and to be able to fire up additional appliances, like coffee machine  while running the entertainment area.
2. Definitely Lithium batteries, no contest there
3. Increased battery capacity, so we opted for 2 X 200Ah batteries
4. Battery equaliser to make sure everything stays nicely aligned
The Kit (Note: I am in no way associated with Energy Tech Store, or posting this for financial gains/compensation)
The easiest way to get what we wanted, was to go for a "DIY Kit" option from Energy Tech Store (https://energytechstore.co.za/3kw-24v-must-backup-kit-with-5-12kwh-revov-2life-12v-200ah-batteries/)
I initially looked at getting a trolley from the likes of Geewiz, but their trolleys are not big enough for the batteries, so this will be a full-on DIY job
REVOV did not have batteries in stock, so we ended up with RAYSTECH 2560S Pro 200Ah batteries (https://energytechstore.co.za/raystech-2-56kwh-lifepo4-battery-12-8v-200ah/)
The Build
Not wanting the inverter to be mounted flat, the trolley would need a "chair style" design.
The trolleys were built using what my dad had in his workshop, including the panels and back that were cut from old Computer/storage boxes
The original design was modified slightly, as when you have the parts on the same panel, things are different to what you expected
For the rest I am not going to explain, as it is quite self explanatory how things progressed
Last pic shows comparison to the Ellies Trolley
Final installation spot:
