December 16, 20232 yr Здравейте, Първо, извинявам се, но превеждам с Google. Имам следния проблем с моя инвертор. Името на Wi-Fi е променено само от W08222... към Wi-Fi_Kit_FF4D379E92. U1-90.19, U2 -12.13, U3- 00.00. Направих рефлаш на mcu, dsp. Някой знае ли как да промени името на модула. Опитах се да го регистрирам с новото име. Казва, че не е правилно. Благодаря ви предварително Edited December 16, 20232 yr by mitkozay
December 17, 20232 yr 9 hours ago, mitkozay said: Здравейте, Първо, извинявам се, но превеждам с Google. Имам следния проблем с моя инвертор. Google translation: > Hello, First, I'm sorry, but I'm translating with Google. I have the following problem with my inverter. You somehow ended up posting in Bulgarian. Quote Wi-Fi name only changed from W08222... to Wi-Fi_Kit_FF4D379E92. U1-90.19, U2 -12.13, U3- 00.00. I reflashed the mcu, dsp. Does anyone know how to change the module name. I tried to register it with the new name. He says it's not right. thank you in advance Sorry, I know nothing about the WiFi devices for these inverters. Hopefully others will comment, now that your problem is stated in English.
