November 21, 20187 yr Good day All, Been lurking around the site for a bit and thanks to all for the posts. Unfortunately only found the site a bit late into my research but a lot of posts have helped in confirming decisions made etc. Plan is for a new off-grid installation to go into a new dwelling recently purchased in the KZN Midlands. The idea was not to go off-grid immediately but after getting the prices from Eskom just for monthly line rental (it location of the dwelling is considered rural), the decision became a no brainer. The dwelling is a relatively small set-up, 1 bed, 1 bath and I've sized the system from average power figures from the spot where I currently live. The existing wiring in the new place is extremely basic so plan is to replace what is there, lights will all be LED, gas stove/oven and gas water heater. The plan is to allow for generator back-up, to feed back into the system should there be extended periods of crappy weather. The heart of the system going in includes: 10 x 355W Canadian Solar Panels (Plan is to add 2 more ASAP) Goodwe 5048D-ES 5 x 2.4kW/h Pylon Tech US2000B batteries Hoping to start the installation in the next couple of weeks, so a couple questions my follow, if I can't find them searching existing posts.
November 21, 20187 yr Author 3 minutes ago, 175SBU said: Welcome Super_mil, i'm also new just signed up. Thanks Sbu. Should be an interesting journey 🙂
November 21, 20187 yr Hi SM Welcome to the forum. A goodwe may not suit your needs if you plan to run offgrid. It is strictly a hybrid inverter and does not like a gennie as its grid source. If you are off grid then you are going to need a gennie.
November 22, 20187 yr Author Noted Chris, thanks for the info. For now I'm committed to the Goodwe as I've already purchased the item.
August 26, 20197 yr 17 hours ago, Pierre said: How is you system doing now? Also interested. Would like to know more specifically how the Pylon Tech batteries are holding up.
