December 25, 20232 yr Does anyone know if you can set a solis-rhi-3.6k-48es-dc inverter to stay on all of the time? instead of turning of when it gets dark. Thank you
December 25, 20232 yr 1 hour ago, johnch121 said: Does anyone know if you can set a solis-rhi-3.6k-48es-dc inverter to stay on all of the time? instead of turning of when it gets dark. Thank you Ensure it is on auto which is the default. Does the grid side works correct when grid is off?
December 25, 20232 yr Author 5 hours ago, Scorp007 said: Ensure it is on auto which is the default. Does the grid side works correct when grid is off? The grid is always on, Sorry I do not know what you mean by Ensure it is on auto which is the default? Thank you
December 25, 20232 yr 1 hour ago, johnch121 said: The grid is always on, Sorry I do not know what you mean by Ensure it is on auto which is the default? Thank you Sorry I forgot to post the picture I intended. Have a look in the manual.
December 26, 20232 yr On 2023/12/25 at 10:48 AM, johnch121 said: Does anyone know if you can set a solis-rhi-3.6k-48es-dc inverter to stay on all of the time? instead of turning of when it gets dark. Thank you Sounds like you don't have a battery hooked up and it's running as grid tied. Without battery, when the sun goes down the inverter powers off even with AC present. This is by design.
