December 27, 20232 yr Hi all, I'm getting a single phase hybrid inverter installed in the next few days. I have a 3 phase house with only 2 phases coming into it... (long story involving a storm) Current inverter is running 1 phase (whole house) and only the stove is on phase 2 I believe the ct clamp should go between the council meter and the dB but on which phase. Or should I get the sparky to put the stove on phase 1 and ct on it to? Confused...
December 28, 20232 yr CT should go onto phase 1 in my opinion. But yes, get the stove moved to the same phase. And then maybe change your council feed from three phase to single phase, unless there's some reason why you need three phase power? Edited December 28, 20232 yr by p_i
