Sunsynk F41 Issues... please help
2 hours ago, Wildebees said:
2 x 12kw SS in parallel. I cannot get this system to work more than a day.
Firmware is updated, i checked all wiring and replaced comms cables.
Try reducing your load and run 1st on no1 inverter only and then try running on no2 only.
With your fault code there should be a description you did not mention which relates to the fact it is a paralleling error.
