Solar inverter does not detect panels after fixing error code 09
After fixing error code 09 (DC bus soft start failed) by replacing a few MOSFETs and IGBTs, the solar inverter stopped detecting solar panels. I checked the voltage at the fuse (before and after) and at the end of the cable. In all cases, it read 400 V. But Immediately after connecting the cables to the inverter, the voltage dropped to 0 V. Other parts of the inverter are working: it detects the battery and mains.
The inverter worked completely fine before the code so I suspect the inverter and not the panels.
May be if you indicate at the end of which cables did you measure.
Sorry if this is a stupid question. Just trying to know which points you measured the values.
Code 09 suggest you have an Axpert type of inverter, but that is speculatiion.
400vdc Pv voltage suggest it is a high voltage pv machine eg MKS3 or upwards (kodak), but that is speculation.
Can you perhaps send us detail on your machine?
It's MKS2 but still, good guess.
This is the label:
I would take a picture of my inverter but it's disassembled. Here's a generic picture:
