January 8, 20197 yr Good day i need some guidance is my Sum correct and will it work on the below invert er battery bank VOL-MKSII-5K-US2000B-PLUS-4.8-T1 Alternative will this work with the Mecer inverter T105 6V 225 X8 Note geysers will be on gas Oven and hub gas can i run the below Day time only wash machine hot wash dish washer hot wash 24/7 Old fridge and freezer 30 od years old night Frige freezer TV LED Lights Laptop Internet Solar Panel panel array CS6U-335P-F35 3 series V 112.2 A 8.96 Parallel Switch to power of panel flow to inverter MKS 2 Mecer 5KVA off grid invert er charge Fail over ( 5.5KVA) generator V 224.4 A 17.92 3 series V 112.2 A 8.96
January 8, 20197 yr Welcome wehanvdw. My first thought, replace the "Old fridge and freezer 30 odd years old " with a A++ fridge as soon as you can. It pushes the usage of the system up immensely, as these older fridges are very inefficient. Daytime makes no difference, unless it is cloudy and evening use is can become the biggest Eskom expense in any event. You are aware that gas costs about the same as Eskom, and that at times one cannot get gas? Geyser on EV tubes, in my experience, are seriously efficient if certain small actions are taken like people shower mornings OR evenings, not at both times, and getting a larger geyser. You could have months of hot water with no Eskom costs if managed properly. Because solar starts with getting a very low average consumption. For example, ones usage is very high. You reduce that to 1 quarter using efficient devices, switching things off with some lifestyle changes. Then you solarize ... if the expenses incurred can generate you more savings ... it can become a tough one in the end. Or, basta that, I want solar, and go all out. :-) Also keep in mind the new regulations that are already out in CoCT ito inverters and what may or may not connect to your DB board. Others will be along shortly with more thoughts.
January 8, 20197 yr 4 minutes ago, The Terrible Triplett said: Also keep in mind the new regulations that are already out in CoCT ito inverters and what may or may not connect to your DB board. There are some questions about the legality of the Voltronic inverters. This is not to start another food fight in the cafeteria... just to say that if you haven't bought the machine yet, you may save some stress and potential heartache by looking at something else.
January 8, 20197 yr Author if i replace the fridge and freezer will i be able to lower my inverter needs . friend is running off grid for 5 years know . 8 X 250w 2 string 3 kva inverter outback changer controller . option on the trogan 105 X8 225 ah .
