February 18, 20242 yr Hi guys, Have anyone noticed the first (0-25%) charge light of a Volta battery flash red when battery is fully charged? BMS comms working with 5kw Deye inverter, single battery, float charge disabled. Deye also reports 0x000C alarm code on BMS. Any help would be appreciated!
March 6, 20242 yr Francois I have the same problem that when SOC is 100% full the red ligh starts flashing?
April 3, 20242 yr HI Francois/ Frik . i have the same issue . have you guys manage to find a solution? If so pls share thanks
April 3, 20242 yr My mom's 5 kw deye with vestwood 48 lithium when 100% charged the alm red light starts flashing so it's not just your setups . From checking volts the volts are around 54.4 v this is 3.62 volts per cel don't think it's good to maintain charge at such high volts .
