I have a new system installed just more then a month ago, and are new to this setup.
5KWA Mecer inverter, with 2x 4.8Vdc Li-ion Leoch batteries, and 12x 330W panels.
system in general really works fine.
I have 3 issues I want to run by you please.
1. When my battries are fully changed, this is usually during the day, inverter switch over to them, and just use battery power until empty. see photo.
this results in losing all the pv power for that day/time. Should this not be ballanced?
2.Battery indicator on inverter shows almost full, but then are empty on the battery display?
3. With eskom power and pv, sometimes the battries done charge, even though its needed or can as they have capacity. Something to do with the load maybe?
Is this a common issues or easily solved one with a firware upgrade maybe?
When I reset the system it run fine again for that day. tomorrow same thing.
Any suggestions will be highly appreciated?
thx
Jacques
Hi Jacques, congrats on your new system and welcome to the sun junkies club.
Can you send your inverter settings ?
1) Long press on the enter button on inverter panel, -> 00 and 3 letters eitheir Util, Sbu or Sol,
2) using the up or down buttons go through all your menu settings from the 00 above all the way to 30 or 31 and record all the value
3) Dont worry if some menu values are missing.
When done press esc button. Lets take it from there..
Morning Guys, thank for the reply, here are the settings:
01-SBU
02-60A
03-APL
04-5d5 or SdS
05-USE
06-LTE
07-TTD
09-50Hz
11-30A
12-46v
13-54v
16-SNU
18-60N
19-ESP
20-LON
22-AON
23-byd
25-Fd5
26-56.4v
27-54Ov
28-PAL
29-42Ov
30-ONE
31-SBE
32-Aut
  • 33-Ed5
34-58.4v
35--60
36-120
37-30d
38-dl 5
39-Ad5 or S
