Sunsynk Settings with 3 Dyness BX51100 batteries
Good day,
I have an Existing installation with 2 Dyness BX51100 batteries. I recently installed a 3rd Dynes BX51100.
I just need some assistance with the Battery settings. Please see pictures and advice if anything needs to be changed or is settings correct.
Thanks in Advance
X51100
Battery Type LiFePO4
Nominal Battery Energy 5.12 kWh
Nominal Capacity 100Ah
Nominal Voltage 51.2V
Operating Voltage 44.8 ~ 57.6V
Recommended C Rate 0.5C
Recommended Charge/Discharge Current 50A
Max. Power Charge/Discharge Current 75A
Peak Power Charge/Discharge Current 100A (15s)
Depth of Discharge (DOD) 95%
Net Weight 50 kg
Dimension[W*D*H] 558*545*150 mm
Charging Temp. Range 0~55℃
Discharging Temp. Range -20~55℃
Communication CAN/RS485/RS232
Cycle Life[1] ≥6000 Cycles
Protection Level lP20
Expansion up to 30 units in parallel
Pros Can be used in both off-grid and hybrid setups, compact design
Edited by Gerhard van Zyl
Mistake on Description
  • Gerhard van Zyl changed the title to Sunsynk Settings with 3 Dyness BX51100 batteries
Hi, untick the 'Activate' box and i would suggest to increase the charge and discharge values.
The batt specifications suggest  a charge/discharge value of 50A.  You can thus safely increase the values to 150A for the 3 batteries.  The BMS would manage  the chimage.png.c197ff5dfbbf29bdf4aa07200d096dd8.pngarging/ discharging amperages according to the parameters of the battery design and chemistry.
Edited by CobusK
Hi G, this option will help to recover a battery that's been discharged beyond it's lowest threshold by activating a slow charge mode from either the grid or PV.  It is mainly for AGM, flooded or Gel batteries, not lithium.  The BMS controls lithium.
