Axpert MKS-3000-24 firmware
Hi,
i'm looking for firmware for axpert MKS 3000 (non plus version, MPPT only 600W).
Does anybody know where to get it?
Dumi
Usual story: apart from a handful of cases, you can only get the appropriate firmware update file from the manufacturer, via your reseller, sending them the serial number.
As far as I know, your case isn't one of the handful where they are available elsewhere.
Thanks for your answer.
I bought Axpert from second hand, from another user. So i don't know reseler. I send email to Voltronic power, but wihtou reply :-(, maybe i have bad address.
  • 2 years later...
Coulomb - You and me both. My fans don't want to switch off after certain amout of battery drain and fully charged again. Have to kill the incomming ac and back on again and fans go off. If the battery drain is less than 25% then the fans work normally. WEIRD
Anyone had any luck getting firmware ? I see the 5kva ones are easily found.
What is the existing firmware for this model? I have 18.22, probably quite old, but it might be newer than what you have, if it's suitable.
  • 1 year later...
5 hours ago, oblitum said:
can someone send me a 24v firmware for a 3KVA MPPT?
There are many models that fit that description: PF1 versus PF0.8, plus versus not, DSP processor versus Freescale processor.
What was the original firmware version, if you can remember?
Edit: failing that, was is it running now, and what are the problems?
These images are from before loading the wrong firmware. I have only modified the main cpu. Now even if I load another s19 file correctly, it still shows the same firmware version, why?
Unfortunately, my lower power firmware collection is woefully incomplete; I have no 06.xx firmware at all. So I can't help with updates or analysing what it's doing.
That's very strange. I can't explain it.
