March 21, 20242 yr Hi all So according to the spec sheet the Sunsynk Powerlynk X and XL can handle a bypass current of 40 amps. Does this mean that if Eskom is connected the inverter can handle loads of 40 amps without an issue for extended periods of time, eg the entire day? Obviously once Eskom fails you are reduced to 24 amps (for XL model). Also what does "Output THD (Resistor Load)" mean? I am assuming it has to do with power factor, in this 3% case 0,97 leading to 0,97 lagging TIA
