March 25, 20242 yr Hi I have setup the Solar assistant that it must only export when battery is full, but as soon as I turn this on, it starts to export. The other issue with this is it seems to even take away power from the battery charging to try and "reach" the export amount that is set, I have also selected priority load. I thought with this setting that it would first charge the battery to 100 soc and then export excess to the grid. What am I missing to achieve this? Thanks Edited March 25, 20242 yr by Greglsh
