Shutdown and restart a RCT Axpert inverter
I have an RCT Axpert 5kVA inverter with a Polytech US3000C battery. I want to shut down the inverter at 10 PM and start it again at 5 AM. Would I be able to do this with Solar Assist, and if so, how?
I believe I can shut down the inverter using power management automation by setting the shutdown battery voltage to 51V. However, how would I restart the inverter again at 5am.
I was looking at this today and the automation works to shutdown the inverter, but it doesn't start the inverter again.
It change the shutdown voltage to 52v at 13h30 and the inverter shutdown, but it doesn't change it back to the original value(47v) at 13h35. So the inverter doesn't come back on again.
I was able to change the value manually back to 47v and then the inverter starts again.
Edited by TheOracle
  • 5 months later...
Have you managed to do it ?
