March 28, 20242 yr Hi I have 2 Mecer Sol-i-ax-11m's in parallel. I want a total maximum charging current of 120A (setting 02). Do I set each inverter to 60A (i.e. they are cumulative and will then give me a total of 120A) or do I set each of them to 120A? I cant find this answer in any of the manuals. Many thanks!
March 28, 20242 yr 14 minutes ago, Deonbayly said: Hi I have 2 Mecer Sol-i-ax-11m's in parallel. I want a total maximum charging current of 120A (setting 02). Do I set each inverter to 60A (i.e. they are cumulative and will then give me a total of 120A) or do I set each of them to 120A? I cant find this answer in any of the manuals. Many thanks! 60 amps on each will give you 120amps in total.
March 28, 20242 yr Author 4 minutes ago, TaliaB said: 60 amps on each will give you 120amps in total. What a pleasure! Thank you TaliaB!
