Nadeem Ahmed Posted April 5 Share Posted April 5 (edited) I have recently installed an Hybrid solar inverter. It is 6KW Inverter (IP65) with dual MPPT controllers. It supports 9KW panels on both MPPTs (combined, meaning 4.5KW on each MPPT). I have the following configurations of PV panels installed: - MPPT1: 325W x 9 + 320W x 4 = 4205Watts (All connected in series) MPPT2: 585W x 8 = 4680W One of my friend mentioned that we should use the exact same configuration with both MPPTs. Can someone please guide me on this? Thanks in advance. Nadeem Onyx PV9000.pdf Edited April 5 by Nadeem Ahmed Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted April 5 Share Posted April 5 3 hours ago, Nadeem Ahmed said: I have recently installed an Hybrid solar inverter. It is 6KW Inverter (IP65) with dual MPPT controllers. It supports 9KW panels on both MPPTs (combined, meaning 4.5KW on each MPPT). I have the following configurations of PV panels installed: - MPPT1: 325W x 9 + 320W x 4 = 4205Watts (All connected in series) MPPT2: 585W x 8 = 4680W One of my friend mentioned that we should use the exact same configuration with both MPPTs. Can someone please guide me on this? Thanks in advance. Nadeem Onyx PV9000.pdf 1.21 MB · 1 download Without looking at specs the 2 MPPTs don't have to be the same value or configuration. Just as you don't have to use both. You can have 1 connected and the 2nd one future. That is a clear indication they don't have to be the same. Nadeem Ahmed, zsde and BritishRacingGreen 3 Quote Link to comment Share on other sites More sharing options...
SYC Posted April 5 Share Posted April 5 5 hours ago, Nadeem Ahmed said: Can someone please guide me on this? As long as you dont exceed 500VDC per string to be safe you should be good. On the 9+4 the 325w will work at 320w only meaning you will loss 45w which is minimal. Nadeem Ahmed 1 Quote Link to comment Share on other sites More sharing options...
Nadeem Ahmed Posted April 13 Author Share Posted April 13 On 2024/04/06 at 1:13 AM, SYC said: As long as you dont exceed 500VDC per string to be safe you should be good. On the 9+4 the 325w will work at 320w only meaning you will loss 45w which is minimal. Thanks for sharing your experienced views. Quote Link to comment Share on other sites More sharing options...
