May 20, 20242 yr I have 2 x 5kw growatts in parallel and both has it`s own dongle--On the shine app and the server I can only view one inverter`s output at a time --I can switch between the two inverters but that is not what I want--I need the combined output and PV input---On the (All Devices) page I can get the combined power that was generated---Any help please----Sorry I do not have a raspberry pi
May 20, 20242 yr It seems you are in the DataLogger Tab which gives you the individual Inverter totals. Don't you have a "Plant" tab? The mobile app has that and that provides the Totals for your "plant". I use Solar Assistant as a much better substitute, the limited data and functionality in the Growatt software being the prime reason I just had a look at the online Website app and if you go to the Dashboard part it states that it should provide you with the totals of both. Mine is offline as I never even connected the dongle of my second Inverter. Edited May 20, 20242 yr by zsde
