New member , help needed with starting in solar please
Howzit all
I am in Rustenburg and realy want to -need to get onto the solar train.....reasons for this is eskom and the great xtate of the grid and the other is to try and save some bucks.
I have about r90000-00 to invest in a solar system.What should i be looking at ?any recommended installer in Rustenburg ?
Do i go for a victron inverter or will the axpert units do ?
All advice will be greatly appreciated !
Have a good night
Morne
Hi Morras.
Welcome here. First things first. I think you have to determine what exactly it is you want to run from solar should Eskom fail. R90K will in most cases not take a normal household off the grid
 Once you decide, please share your plan with us, and I am sure we will be able to give more accurate advice.
As to your question about Victron Vs Axpert. My opinion is definitely Victron.
Morning Jaco
A little more info :
daily usage on prepaid is about 30 units....i have a gas stove top installes already.would love to convert geyser to solar also but i am scared that i dont have enough space on the roof for that and enough pv pannels for a system. My aim is to start with a system that will immediatly lets me use less eskom power and also gives me a good couple of hours worth of backup when the power fails or eskom load sheds.
daily load excluding things like geyser  , washing machine and dishwaser should not exeed 1700 watt.i was thinking of either a 3 of 5 kw victron inverter(multipluss) , some lithium batterys and either 6 or 9 300 watt pannels to start with , hopefully that will be in my budget ?
any decent installers and retailers in the Rustenburg area ?
thabks in advance for al, the help.
Great Idea imo..
This should fit into your budget if you buy from the correct supplies.
I dont know installers in that area.. will send you details of retailers in a PM.
Maybe someone on the forum will know installers in your area.
