May 23, 20242 yr Hi Guys Just a quick question on battery temps. Revov R100 I see my batteries has 4 T temps and they all differ slightly within 1 Celcius. The biggest difference is the one in 24.8c and the other 23.8c the other two is 24.5c and 24.3c Is this acceptable or should they be closer together? Thanks in advance
May 23, 20242 yr 3 minutes ago, Zeus-JKR said: Hi Guys Just a quick question on battery temps. Revov R100 I see my batteries has 4 T temps and they all differ slightly within 1 Celcius. The biggest difference is the one in 24.8c and the other 23.8c the other two is 24.5c and 24.3c Is this acceptable or should they be closer together? Thanks in advance No concern on the level you quote. Even up to 60°is well below the maximum level for lithium. I have no idea where the 4 sensors measures. I myself measure 1 cell and the 2nd sensor is the free inside of the box. The 3rd sensor measures the BMS MOSFETS.
