iPower Windows 2.1.2.0
19 hours ago, Vector_ said:
firmware 2.27 for ISOLAR-SMX-II-5.6Kp
These appear to be based on the Axpert MKS II, but extended to 5.6 kW (MKS II is 5.0 kW), with their own firmware. Unless you can get it from EASun, I believe that this will be very hard to obtain. It does not use standard Axpert firmware, e.g. setting 02 is frequency (50 or 60 Hz); it's setting 09 on Axperts.
  • 3 months later...
Finding specific software and firmware can be tricky. I once needed a hard-to-find program and ended up searching through forums and tech sites. For your case, it might help to check the manufacturer's website or reach out to their support team directly—they often have archives of older versions. Also, try searching through tech community forums where users might have shared similar files. If you end up needing to reset your system for any reason, here’s a guide that might be useful: https://operatingsystems.info/how-to-factory-reset-pc-windows-11/ . It helped me out in a bind.
Edited by Gtechalax
