June 4, 20242 yr Can someone please let me know where can I get the latest firmware for my Pylontech US3000C battery?
June 4, 20242 yr You can get a zip file with versions for the old (2.8) and new (2.1) chip here -> Lithium storage unit Pylontech US2000C/3000C | Effekta | EFFEKTA Regeltechnik GmbH. I have seen V2.2 for the new chip US3000C Pylontech's but haven't been able to source it.
June 6, 20242 yr Author I have upgraded my battery, the version now is B68.6.0.0 (23-07-07) I received the bin file from PylonTech.
June 6, 20242 yr Author I upgraded the firmware, hoping it would solve an issue I had with the battery. In the afternoons, once my battery is fully charged, I use my excess solar power to heat my koi pond. I automatically switch off the heater once the battery's state of charge (SOC) is 94%. But what happened was that the SOC stayed at 94%, although the battery still had a good charge. Unfortunately, the upgrade didn't help. Today the SOC actually went down from 94% to 93%.
June 15, 20242 yr Author 42 minutes ago, Tinbum said: You need to give more details of your set up for anyone to help. You correct, my bad. Please see here for more details about my system:
November 16, 20241 yr On 2024/06/06 at 11:59 AM, TheOracle said: I have upgraded my battery, the version now is B68.6.0.0 (23-07-07) I received the bin file from PylonTech. I have B68.8.0.0 on my newer US3000Cs, anyone having the files, and could share them? I would like to update the older ones as well. edit: to be more precise on the production date and software + board of the 4 pylontechs: Older 2: Production: 20221027 Board: NF4.E2 Board Version: V10R04 Main Soft Version B69.13.1.0 Soft Version 1.7 Boot version 1.0 Comm version 2.0 Release Date:220825 Newer 2: Production: 20240812 Board: not showing Board Version: V10R04 Main Soft Version B68.8.0.0 Soft Version 3.0 Boot version 2.1 Comm version 2.0 Release Date:240725 Since version numbering is not as consistant as one would expect. What is the latest recommended version to run on all 4? sorry for the lack of information on my earlier question Edited November 17, 20241 yr by nibbler79
November 17, 20241 yr On 2024/11/16 at 9:19 AM, nibbler79 said: I have B68.8.0.0 on my newer US3000Cs, anyone having the files, and could share them? I would like to update the older ones as well. edit: to be more precise on the production date and software + board of the 4 pylontechs: Older 2: Production: 20221027 Board: NF4.E2 Board Version: V10R04 Main Soft Version B69.13.1.0 Soft Version 1.7 Boot version 1.0 Comm version 2.0 Release Date:220825 Newer 2: Production: 20240812 Board: not showing Board Version: V10R04 Main Soft Version B68.8.0.0 Soft Version 3.0 Boot version 2.1 Comm version 2.0 Release Date:240725 Since version numbering is not as consistant as one would expect. What is the latest recommended version to run on all 4? sorry for the lack of information on my earlier question Are you sure those are correct? They don't seem to tie up with current thinking. Perhaps Pylontech are trying to confuse us. it may be worth posting part of your serial numbers that show if you have old chip, new chip or a version we have not yet come across.
November 17, 20241 yr 1 minute ago, Tinbum said: Are you sure those are correct? They don't seem to tie up with current thinking. Perhaps Pylontech are trying to confuse us. it may be worth posting part of your serial numbers that show if you have old chip, new chip or a version we have not yet come across. which part shows the chip version?
November 17, 20241 yr On 2024/11/16 at 10:19 AM, nibbler79 said: I have B68.8.0.0 on my newer US3000Cs, anyone having the files, and could share them? I would like to update the older ones as well. edit: to be more precise on the production date and software + board of the 4 pylontechs: Older 2: Production: 20221027 Board: NF4.E2 Board Version: V10R04 Main Soft Version B69.13.1.0 Soft Version 1.7 Boot version 1.0 Comm version 2.0 Release Date:220825 Newer 2: Production: 20240812 Board: not showing Board Version: V10R04 Main Soft Version B68.8.0.0 Soft Version 3.0 Boot version 2.1 Comm version 2.0 Release Date:240725 Since version numbering is not as consistant as one would expect. What is the latest recommended version to run on all 4? sorry for the lack of information on my earlier question Sorry for confusing you. Newer 2 are on different firmware since I downgraded one of them thinking the pack from effekta is newer: Production: 20240812 Board: not showing Board Version: V10R04 Main Soft Version B68.8.0.0 / B68.5.0.0 Soft Version 3.0 / 2.8 Boot version 2.1 Comm version 2.0 Release Date:240725/220902
