July 13, 20242 yr Hi guys, is it possible to raise the battery undervoltage setting on the Solis s6 inverter? I had an issue a few weeks ago with the bad weather causing the battery not to charge for 3 days and the voltage slowly dropped until the battery shut down. I've since changed the force charge setting to prevent this in the future. However I'm wondering why the under voltage protection on my inverter is 2 volts lower than the battery cut off (44V)?
