July 21, 20242 yr Converter problem. It shows the signs of bP! and (15) . It is a solar inverter of the company easun power 3.5kw 24 volts. Can a friend help?
July 21, 20242 yr 6 hours ago, Theo Kaps said: Converter problem. It shows the signs of bP! and (15) . It is a solar inverter of the company easun power 3.5kw 24 volts. Can a friend help? Not sure if your problem is a fault or a warning. Below screenshots from the Easun manual. Should you require a copy of the manual pm me as the file exceeds the allowable upload size.
