July 30, 20241 yr I have borehole motor that is manged by smart controller based on various levels. The controller is always powered but pump relay not closed. I would like to wire a device to the controller output to detect 220V voltage present and send push notifcation and make entry in log file. Do I need something like load shedding detector or can SonOff mini work on its own?
October 17, 20241 yr Hi Jacques You could use the LoadShedder to monitor the on and off us IFTTT for record keeping. Otherwise run it through a POWR32D and that will keep track of power consumption for six months and you can download to csv. Aleks Sonoff Africa
