March 13, 20197 yr Were starting to play around with these Goodwe machines and the various settings; not much info around though... Wish it was as easy as Victron ESS lol want to set it up as self-consumption during the day from solar - but it must keep the batteries fully charged for load shedding and not cycle... any thoughts
March 13, 20197 yr there is a mode called backup. It does exactly what you are looking for. I assume you know how to use the PV Master or EzManage apps.
March 13, 20197 yr 16 minutes ago, Synergy said: Wish it was as easy as Victron ESS lol I swear that's the first time I heard someone call it easy 🙂
March 13, 20197 yr Author 16 minutes ago, plonkster said: I swear that's the first time I heard someone call it easy 🙂 Been working with Victron for Ages, love their machines, you can really tailor-make them to your application
March 13, 20197 yr Author 42 minutes ago, Fuenkli said: there is a mode called backup. It does exactly what you are looking for. I assume you know how to use the PV Master or EzManage apps. Thanks Fuenkli, yes used that setting, it discharges 10% though - which is not the issue, will then charge up from grid again and then discharge 10% again...and just continues like that... contacted the suppliers if they have answers ... will keep you posted
March 13, 20197 yr 10 minutes ago, Synergy said: yes used that setting, it discharges 10% though definitely not ok. I would contact Goodwe China.
January 3, 20206 yr On 2019/03/13 at 1:26 PM, Synergy said: Been working with Victron for Ages, love their machines, you can really tailor-make them to your application Hi, I like very much your system, at this moment I project similar system. in my system I pretend have 30 kWp photovoltaic, 2 inverter fronius symo 15, 3 inverters victron quattro 8000, and 9 block byd 13.8 kWh. but i don't have sure about the equipment because i pretend install 3 BYD battery for each one inverter Victron, and i don't know if is possible. Can you help me? my system working in ac coupling with fronius, i have 30 kW pv, with 2 fronius symo 15. i pretend install 3 Victron quattro 8000, working in triphase mode and i pretend install Collor gx to monitory and controller all system. Do you think is possible? thanks.
