October 4, 20241 yr 9 minutes ago, GysEls said: Hi, does anyone know where can I get the pin layout of can port on the battery? Attached Revov compatibility Word doc all information you need regarding Can wired to your inverter. See below attached. Revov_Compatibility List.docx
October 4, 20241 yr 2 hours ago, GysEls said: is it only that two wires i need? Yes the signal is broadcast over two communication wires to ensure signal integrity is maintained, these wires are twisted together and are referred to as CAN High and CAN Low.
