October 28, 20241 yr Hi I have a solar invertr : Felicity IVEM5048 the unit is damaged (lost nutral from grid) after testing the board I found : 4 Damaged Mosfets on INPUT side ( Mosfet : NCEP026N10) 4 Damaged Mosfets on OUTPUT side ( Mosfet : MIW75N65F) I checked drive section (resistors , npn+pnp transistors , optocoupler ... ) nothing damaged I couldn't find the same mosfet equivalent for damaged parts , and the closest equivalent has lower Id paramiter (Drain Current-Continuous) my question : can I replace mosfet with same voltage and Rds but with lower Id ?
October 29, 20241 yr On 2024/10/28 at 7:26 PM, vanguardviper said: Hi I have a solar invertr : Felicity IVEM5048 the unit is damaged (lost nutral from grid) after testing the board I found : 4 Damaged Mosfets on INPUT side ( Mosfet : NCEP026N10) 4 Damaged Mosfets on OUTPUT side ( Mosfet : MIW75N65F) I checked drive section (resistors , npn+pnp transistors , optocoupler ... ) nothing damaged I couldn't find the same mosfet equivalent for damaged parts , and the closest equivalent has lower Id paramiter (Drain Current-Continuous) my question : can I replace mosfet with same voltage and Rds but with lower Id ? The FETs you need are available on aliexpress and other on line sellers. Edited October 29, 20241 yr by Scorp007
November 1, 20241 yr Author On 2024/10/29 at 4:53 PM, Scorp007 said: The FETs you need are available on aliexpress and other on line sellers. I don't have access to online purchase where I am ... and thanks for reply , but that was not my question ! I need to know if I can replace mosfets with deferent parameters , even if they are lower than originals . the original mosfet has a current (Id) of max 200 amps , the closest I could find has 180 amps of max current .
November 1, 20241 yr 1 hour ago, vanguardviper said: I don't have access to online purchase where I am ... and thanks for reply , but that was not my question ! I need to know if I can replace mosfets with deferent parameters , even if they are lower than originals . the original mosfet has a current (Id) of max 200 amps , the closest I could find has 180 amps of max current . Sorry I did not answer the question. I belief it is not good practise to downgrade component conducting high current like FETs. Just my 2c.
November 1, 20241 yr 2 hours ago, Scorp007 said: I belief it is not good practise to downgrade component conducting high current like FETs. Quite true in general. However, in this case, it's fanciful to expect to get 200 A through the thin leads on these TO-220 devices. So yes, a 180 A part should be OK. It should be rated for at least 80 V; 100 V will give better margins.
November 1, 20241 yr 4 hours ago, Coulomb said: Quite true in general. However, in this case, it's fanciful to expect to get 200 A through the thin leads on these TO-220 devices. So yes, a 180 A part should be OK. It should be rated for at least 80 V; 100 V will give better margins. Thanks for the reply. May be I am too sensitive on FETs as we change a number of 84A FETs every day that feed 12V gate motors where the source is only a 7Ah battery.
April 6, 20251 yr On 2024/11/01 at 2:48 PM, Coulomb said:Quite true in general. However, in this case, it's fanciful to expect to get 200 A through the thin leads on these TO-220 devices. So yes, a 180 A part should be OK. It should be rated for at least 80 V; 100 V will give better margins.Please my ivem5048 is not coming on where should I look and pay attention to am lost
April 7, 20251 yr 7 hours ago, joshua said:my ivem5048 is not coming on where should I look and pay attention toThe main power supply, especially the part that "bootstraps" it on, basically the part around the two transistors below from my traced schematic:This circuit is usually near the large square yellow banded "transformer", as in the middle of this photo:It could also be capacitors worn out in that power supply; see this post for typical replacements.
