Gerhard
mecer 8kw inverter my inverter drop the power for a second when it is suppose to handle a small`spike`this happen when my swimmingpool is on my aircon is on and i switch another load on example like the borehole or sometimes as much as a kettle. just enough drop to reset the plugs. The load is then not higher than 6kw. constant.
The borehole pump will have a substantial switch-on surge, probably 5-7x the rated power. This in addition to your other loads could easily overload the inverter, especially if it's relying on the battery, and the battery is weak.
