November 22, 20241 yr Author 2 hours ago, TaliaB said: @Jade4 Give me the heads up when you are ready to sell the 4 x Trina panels i will use them with the Victron Blue Smart 100/50 mppt in 2S2P configuration. i see your location states cape town. i am based in Gauteng.
November 22, 20241 yr 2 hours ago, Jade4 said: i see your location states cape town. i am based in Gauteng. No problem i have a truck that regularly run between Cpt and Gauteng.
November 22, 20241 yr Author 5 hours ago, TaliaB said: My suggestion on solar panel replacement would be 4 x Ja 550w or if you have space 5 x JA 550w 5S1P the latter will work great providing ~210v Vmp @ 13A. Below data sheet of the JA panel range you can consider. I have use these panels in my installations and they work great with the 5kw Sunsynk. JA-Solar-525W-550W.pdf 1.26 MB · 2 downloads this is an aerial view of my roof and where the current panels are situated. could anyone advise if 5 or even 6 panels are possible once i remove the current 4 panels or should i just stick with 4 panels based on my roof space?( "master sunsynk installer" stated that only 4 panels could be fitted based on the current roof space and that is why i went with 4 panels only)
November 22, 20241 yr Author 15 minutes ago, TaliaB said: No problem i have a truck that regularly run between Cpt and Gauteng. cool. sent you a message as well.
