November 26, 20241 yr Hello, I have a Deye inverter, which after a hardware problem (replacement of transistors) no longer works normally. There is no error indication, but it does not generate voltage at the output. The display lights up normally, the default settings have been returned. Is there a possibility that it has locked itself in some way?
April 26, 20251 yr 6 minutes ago, Moluh Deredd said:Hey VictorI am facing this same problemWere you able to solve this??Can you see on the display that it actually does charge the battery from PV? If it does then it seems it is only the DC to AC output that is at fault. If the battery is below the timer setting which is active does it also not use grid to produce a AC on the output?
