December 5, 20241 yr Boa tarde, Alguem consegue arranjar o frimware mais recente para estes inversores?
December 7, 20241 yr Author Bom dia, são estes os valores. Consegue arranjar os todosos frimwares (U1, U2, U3) certos para estes inversores? Também não consigo fazer conecção via wifi aos inversores.
December 7, 20241 yr Author 1 minute ago, Sérgio Fernandes said: Bom dia, são estes os valores. Consegue arranjar os todosos frimwares (U1, U2, U3) certos para estes inversores? Também não consigo fazer conecção via wifi aos inversores.
December 11, 20241 yr The latest firmware for your model is over a year old now, but it has the "presumed good" MPPT logic (so the "stuck at 90 V issue is largely solved). It's 46.82, available here: https://forums.aeva.asn.au/viewtopic.php?p=102981#p102981 Edit: You may want to update the display firmware as well, as 112.19 is quite old. The latest in the y12.xx display firmwares is display firmware version 12.28. Edited December 11, 20241 yr by Coulomb
December 11, 20241 yr Author Bom dia, Tem algum frimware para U3? A versão do meu é 00.00 e não sei se é por isso que não consigo que os inversores liguem ao router para ter a informação online. Já tentei de tudo e também várias app e não consigo de maneira nenhuma fazer a ligação dos inversores ao router. Pode ajudar sobre isso? Obrigado.
December 12, 20241 yr I have never seen any firmware update files for the Bluetooth / WiFi processor, and I don't think that there is actually a mechanism for updating it. Showing 00.00 as the U3 firmware version seems to be common, whether Bluetooth/WiFi is working or not, so sadly it doesn't seem to tell us anything useful. Sorry, I don't use these, so I have no idea how to fix it. PS, please post in English.
