January 9, 20251 yr Are any of the Pylontech, Shoto, Fox, Deye, Dyness or any other well known inverter brands compatible with a LUMO battery Edited January 9, 20251 yr by ThatoM
January 11, 20251 yr Hi ThatoM, welcome to the forum. It depends what you understand with compatible. Basically any battery that has the right terminal voltage and sufficient capacity is compatible with any inverter. Another story however is compatibility of BMS with inverters. But you can run a compatible system very well without BMS to inverter communication, as I do for over 4 years. It is important to make the right setting on the inverter according to battery specification.
